Make sure you turn off auto focus on your lens (manually focus or pre-focus it) when you do long exposure. Also, turn off the continuous auto-focus mode on your camera if you are on it. I have found out that even you have a heavy tripod, strong wind still can cause camera shake = blurry pix. Your pix is underexposed like others mentioned which caused noise... It looks like you might need to go to Bulb exposure setting (I think Canon uses the same terminology) and expose this more than 30 seconds. You might need an extra stop of light. It gets tricky on sunset even though your camera gives you the exposure of 30 secs but as the sun is setting... 30 secs later the scene gets darker therefore you are required to expose it longer.
