Maybe, but probably not. Every lens is different, even two samples of the same model line may produce slightly different results. How apparent this is relates largely to the quality of the lens. If you compare a pro lens (Nikon 'Gold Ring' or Canon L) against a consumer kit lens, the differences will be pronounced. If you compare two pro or two consumer lenses, than the differences will likely be less so.
