AshleyS
- Joined
- Jan 22, 2012
- Messages
- 8
- Reaction score
- 2
- Location
- St. Augustine, Fl
- Can others edit my Photos
- Photos NOT OK to edit
Hey guys!
I dropped my shootsac (on concrete..ouchie) with my Canon 100mm 2.8 and 50 1.4 in it. While the 50 is broken and won't focus, the 100mm is just fine. However, I had just slipped an 8gb SD card full of the detail shots into the pocket with the 100mm, before the bag dropped.
Are you following? The 100mm (which was capped at both ends, thank goodness) fell so hard that the SD card under it basically took the weight of it and the gold readable part of the card has a slight bend and the plastic dividers are clearly shifted a bit. It's not broken or cracked at all though.
The card is not readable by my USB cable from camera to Mac, SD card reader, printer card reader, or in the actual camera.
I need the best advice as these are important images and I've learned a great deal. I don't need to be told what I should have done, etc.
Does SanDisc do recovery services for situations like these? Thank you in advance
