Seeking Critique for my first off camera flash photos
robrod14
Northern Va
Hello this weekend i decided to experiment with some off camera flash. I am looking for some feedback on what i can do to get more professional looking pictures. I tend to have better luck with my photos outdoors than i do indoors not sure why, but i will post some indoor shots later. Please critique away... ( have to learn somehow).
Camera: Mark 5d II
Flash: Speedlight 430 exII
Modifier: no modifier
Shutter Speed: 1/200
ISO:640 (i think i left it there from when i was in the house and forgot to change it)
F stop: 9.0
I wanted to shoot wide open at 2.8 but the background was completely blown out and the Shutter Speed wouldn't go faster than 1/200. I believe that has to do with sync speed.
Yes, Rob, outdoors during daylight hours, the 1/200 second top synch speed creates a need for small lens apertures at ISO levels of 200 or higher. Sunny 16 Rule gives ISO 200 at 1/200 second at f/16; at ISO 100, it's still 1/200 second at f/11; Set to an artificially created "Lo" value of say a nominal ISO value of 50, 1/200 second still yields a small aperture of f/8. SO, if you want to be shooting outdoors in bright daylight at f/2.8, you will want either a Neutral Density filter, OR a flash unit that has HSS, or High Speed Synch capability.
HSS-capable flashes are available from Canon, as well as the other 3rd-party makers like Yongnuo. You might also check into some of the special remote triggers like the Phottix Odin triggers, which use special time-delay settings which can allow you to synch flash at faster shutter speeds, so you could get the lens opened up more toward the f/2.8 zone.
For some reason the lighting on the subject doesn't seem to match the scene and it makes it look like she was photoshopped onto the background.
Why would you want to shoot wide open?
I imagine it's to control DOF but look at the background in f9; it's fine.
Use dofmaster.com to get some idea of DOF for your camera/lens combination.
