ORourkeK
- Joined
- Dec 30, 2013
- Messages
- 311
- Reaction score
- 101
- Location
- Philadelphia, PA
- Can others edit my Photos
- Photos OK to edit
- Thread Starter 🔹
- #16
Shutter speed is one of the most important settings in assuring your subject is sharp. Because of this, I like to start by setting my shutter speed. I like to set my starting point at about 1/80. If my subject is moving I will increase it accordingly. I do not like to go below 1/60.
I try to maintain no lower than 1/125sec. I'll turn off VC/VR if I start to get about 1/500.
Next is aperture. For a nice shallow DOF I like to keep my aperture as close to 2.8 as I can. The more people added to the photo, the higher I go. This actually helps with the low light problems my D3100 has.
You want to stop the lens down to maintain the best sharpness throughout, however that lens is pretty sharp wide-open. But you'll have a narrow DOF. I suggest starting at f/5.6 unless you need the extra light.
800 ISO is fine on the D3100. I often took it to 1600--Above that is gets iffy for sure, but still complete usable. This was shot at ISO 2800 with a D3100 using the cheap 55-200mm and it's fine: https://www.flickr.com/photos/80607199@N08/9527687182/sizes/l
Dont worry so much about ISO if it means you need a very slow shutter that will capture your motion or your subject's. While ISO 100 is great for quality, modern cameras handle high ISO values pretty well if you have to sacrifice.
Not a horrible process. But I try, even at short focal lengths, to stay about 1/125sec. Working on your method here helps as well. I have very sharp images with the Tamron at 1/30sec.
Next is focus. You can’t have a sharp subject if your focus is poor. I have been using my focus points to choose what I want to focus. I am going to start using the two step shutter for focusing and see if that helps. I read that it is more effective than selecting a different focus point. Anyone have experience with this?
not quite sure I understand this.
After going through these steps, I still cannot get my subjects as sharp as I would like sometimes. This probable had a lot to do with the lens I was using, and hopefully my new Tamron 24-70 will help. I see some pictures where the subjects almost seem like they are jumping out of the picture they are so sharp. I have yet to be able to achieve this. Am I expecting too much from my 3100? Or am I just not skilled enough yet? Maybe my thought process is completely wrong and someone can point out my mistake.
D3100 and a sharp lens (85mm @ f/2.8): https://www.flickr.com/photos/80607199@N08/9647214582/
It's not the camera; it's the user. I also post all my images and apply sharpening. *This is a must*
My D600 is sharper for sure, but it's not noticeable unless you're looking at full size pictures, then it become apparent. But I've seen MUCH worse...
Cool. Thanks for the info. I will make sure I get myself out of the habit of not going above 800 ISO. I also have to learn how to apply sharpness properly in LR.
