Should I buy the Canon 100-400 L F4.5-5.6?
No it doesn't. All lenses suffer from crop factor on a crop sensor.
All cameras with smaller sensors experience a crop factor and the focal length is lengthened as a result.
I have a 5D with a full size sensor and therefore any lens i fit does exactly what it says on the tin - 24-70 is exactly that.
Certain lenses are designed purely for APS-C sized sensor and don't fit other Canon cameras - eg designed to fit the 20D or rebel and called EF-S fitment.
Those lenses will not fit film SLRs or full frame DSLRs.
On the other hand though all EF lenses will fit all DSLRs
What you say is correct - "All lenses suffer from a crop factor on a crop sensor".
My earlier post was because i do not have a cropped sensor.
Looks like the lens is good for the 5D - thanks for the post to flickr reg.
i know i can ask in the shop but I'd like to find out before i go.
Still thinking about the 150-500 sigma though!!!
Rule one - wiki is not good for specifices
Note that some simple and usually inexpensive cameras have fixed focus lenses which cannot be adjusted[
Whilst the formula is lacking the factor of cropping due to sensor size this is included in the last line from the site
Use of a 35 mm equivalent focal length is particularly common with digital cameras, which often use sensors smaller than 35 mm film, and so require correspondingly shorter focal lengths to achieve a given angle of view, by a factor known as the crop factor.
I should have said that the effect is as if the focal length is increased because the smaller sensor has a narrower field of view.
Perhaps I simplified it too much!!
Oops!
