Skewed Photo
josh2024
Ireland
Hello,
I took this photo from a distance of approx 1 meter directly overhead with the jigsaw flat on the ground. I held the phone horizontal using a small spirit level. The phone is a samsung A53.
Why is it skewed and how can I prevent this?
Welcome aboard. I wonder if the puzzle isn't square (90-degree angles at each corner). It's not uncommon for jugsaw puzzles to be out-of-square. There may be a little distortion from shooting wide (24mm). As far as preventing it, if the problem is that the puzzle is not squared up, you could try a pair of inexpensive drafting triangles (45-90-45 degrees and 30-60-90 degrees). Place them at opposite corners lining up with 90-degrees and use a straightedge (meter-stick) to try to align the sides of the puzzle.
