Different lenses and focal length
TonyE
Spain
Hello all on my first post!
I have a Nikon D3200 and some Nikon lenses I've been using for years.
But it wasn't until now I have realised something weird when comparing two of my lenses, at least up to my understanding of course. I'm a begginer, so It's obvious I'm missing something...
Lens 1 is: AF-S DX NIKKOR 55-200mm f/4-5.6G ED VR II
Photo taken at 200mm:
Lens 2 is: AF-S DX NIKKOR 18-300mm f/3.5-6.3G ED VR
Photo taken at 300mm:
That street number plate is placed several meters far from the camera.
Now I take a photograph of an object placed 2,10m far from the camera.
The 55-200 lens took this photo at 200mm:
whereas the 18-300 lens took this photo at 300mm:
I tought the longer the focal lenght, the narrower the angle of view... independently of the distance.
But this seems not to be the case, at least when comparing two different lenses...
What is the explanation for this?
Thank you very much!
Try a Google search for "Focus Breathing."
Hi, TonyE.
For this question, please post the photos without any cropping, and let us know the EXIF information.
And please come back and let us know you read this.
The first pair of images is what I would expect in a comparison of 200 to 300 millimeters. Without knowing how you've sized or cropped the images, your question cannot be answered. The post above mine is valid; we need the actual images, unresized and uncropped, with the EXIF data from the images.
OP made just one post and has not been back.
Seems to be a common thing here at TPF.
Hà cool, just learned a new thing here today :)
Next time I'm in a shop and a salesman tries to sell me something I'll ask this question: "Do you know if this lens is focus breathing corrected?"
And then notice how his hair instantly turns gray.
I advise doing this breathing technique:
Thanks a lot, this would perfectly explain the issue...although I would have never think of such a difference between those 2 lenses at short distance focus.
PD: "A word to the wise is enough." Congrats RAZKY.
Hi, TonyE.
Hi. Images were not cropped in the sense you seem to mean (maybe +-1 pixel error at most at the edge from manually taken a region screenshot, which is nothing compared to what I'm trying to show you). Why would I have cropped them if i'm trying to compare focal lenght and the actual results?
Only meaninfull difference on EXIF apart from timestamp are lens model and "theoretical" (now that I know) focal lenght value, both of which are the ones I stated. Not even a difference in aperture or shutter speed.
I suppose you only want to make sure a newbie is not messing up things... but I consider question solved by RAZKY, so I won't upload new info. Thanks a lot anyway.
Maybe not everyone has the time to daily check and reply in forums. Please relax...coming back after one week is not so much :^). Thanks again.
The difference can be surprising - the field of view of one version of the 70~200 f/2.8 Nikkor, set at 200 and the closest distance, is said to equal that of a 135mm prime lens at the same distance.
Reduction of FL is stronger when focused rather close. My 28-300 is really about 135mm at close focus. This effect is due to the "internal focus" system of many modern lenses, as opposed to "unit focus" of traditional designs.
Traditional design moves the whole lens further from the film plane in order to focus closer. IF leaves the lenses at a constant distance, but by reducing the actual FL the lens is now further from the film plane than the appropriate infinity focus position for that new shorter FL.
If that is hard to follow as info by text, google a source that has graphical information. Regardless, you need to understand the the infinity focus position of ANY lens is the position where the "optic center" of the lens Xmm from the film plane when X is the FL. If the distance to the film plane is LONGER than the FL thrn that lens is fogusing closer than infinity. More and more distance (from the film plane) will focus closer and closer.
TO FOCUS CLOSER, EITHER MOVE THE LENS FURTHER FROM THE FP .... OR (alternately) LEAVE THE LENS AT ITS INFINITY DISTANCE (FROM THE FP) BUT REDUCE THE ACTUAL FL SO THAT THE DISTANCE FROM THE FP THEN BECOMES TOO LONG FOR INFINITY FOCUS. The former is "unit focusing" (complete optical section moving further from FP) while the latter is "internal focusing" (a few elements shift around to cause a reduced FL).
Sorry, all caps not meant as "shouting", just writing a "headline" item.
