Spider shots may be common but the position of the spider hanging from the plant makes this one visually different. Diagonal lines and positioning which are part of artistic composition are used well here with the leg of the spider and the thread of the web. The frond and one of the other legs are creating diagonal lines toward the other side of the image. Colour and sharpness are excellent and depth of field is used well to reduce the background distractions. The problem I see is that the ground cover and the sky? are visually splitting the spider. Some cloning might be done to reduce that.
skieur
Huh???
What the ...
skieur - it might help to slip in the name of the photographer or even direct quote the post itself from the other thread (you can click quote in the other thread and then edit the quoted content in the text box to omit any parts you don't want - then just copy the whole of the text and paste it in here - quotes, even with the numbers and name that auto link back to the original post - can be made across different threads.
Ps you might also want to edit your first post in this new thread (even if just to refer back to the starting thread as to where the photos are coming from.
GeorgieGirl- its a photo by Ganch from the photo posting thread: http://www.thephotoforum.com/forum/...-brutally-honest-critique-your-photo-huh.html
Overread: Do I need to report again a certain comment that I would like removed from another related thread?
skieur
