hello,
Have been seeing some photos on some online photo sites lately where the photographer uses small apertures like f/16 to shoot normal landscapes that don't necessarily need a wide depth of field. I've also seen advice to use f/16 to shoot night shots of Christmas lights. Previously I had thought that the smallest aperture you should use is f/11 unless you want extreme depth of fields or sunburst effects
Any input would be appreciated.
Use any f-stop you want. They all have trade-offs.
Landscapes are usually shot with a broad depth of field and that usually means using a high f-stop value... f/16... f/22.
As you stop down to higher f-stops, the camera becomes 'diffraction limited'. Light doesn't technically focus to an individual point (due to it's wave nature). It focuses to something called an Airy Disk (nothing to do with "air" -- it's named for the astronomer who discovered it... George Airy.) Anyway, as you push light through a tinier opening, the size of the Airy Disk gets bigger. There is a point where the size of a small aperture increases the size of the Airy disk to the point where it can not fit on a single "pixel" (sensors don't really have "pixels", but that's another thread so I'll stick with "pixel" for simplicity.) This means that a single Airy disk spills across adjacent pixels leaving you with softer focus than you might get at a high f-stop.
So that's the idea... but it turns out we often don't use all the pixels available to us when we create output. The image is resampled to a smaller size for output and that means it's no longer even possible to tell that the camera was shooting at higher "diffraction-limited" f-stop.
The bottom line... you probably don't really need to worry too much about those high f-stops unless you know you plan on using a very high output size and the image will be subject to close inspection.
You can learn more about diffraction limits here:
Diffraction Limited Photography: Pixel Size, Aperture and Airy Disks
Meanwhile... there's a reason you might deliberately want to shoot at a very high f-stop.
It turns out that when you shoot at high f-stops, the tight aperture size causes each point of bright light in the image to throw diffraction spikes. You only get these at high f-stops and the higher you go, the more noticeable they become. These can be very attractive in night-scapes and city-scapes shot at hours when the lights are on.
See:
Tip: Star Bursts | StarCircleAcademy.com llc
