Snake
wackii
Southern California
Getting away from birds a bit. C&C are always welcome!
Really cool snake! Is it a tree viper?
Lighting isn't the greatest though.
Trimeresurus popeorum? Beautiful viper... but the choice of DOF and lack of good lighting don't help the image.
I am assuming you had the camera on a tripod? With a 1 second exposure, I hope so.... stopping down a couple of stops would have really helped, and raising the ISO would have also. I have seen clean images from the D7000 at up to ISO 6400... I am sure the D7100 woul
d do as well if not better.
EXIF Data
[PhotoME]
PhotoME version: 0.79R17 (Build 856)
[Overview]
URL: http://www.thephotoforum.com/forum/...fe/47985d1371544910-snake-snake-resized45.jpg
File type: JPEG
File size: 586.5 KB
Creation date: 6/17/2013 15:19
Last modification: 6/18/2013 06:32
Make: NIKON CORPORATION (Nikon | Home)
Camera: NIKON D7100
Software: Adobe Photoshop Lightroom 4.4 (Windows)
Dimension: 2297 x 1532 px (3.5 MP, 3:2)
Focal length: 290 mm (equiv. 290 mm)
Aperture: F6.3
Exposure time: 1"
ISO speed rating: 200/24°
Program: Manual
Metering Mode: Spot
White Balance: Auto
Flash: Flash did not fire, compulsory flash mode
I think you are right about tree viper (not too sure). Unfortunately, light is too good.
EXIF Data
[PhotoME]
[Overview]
File type: JPEG
File size: 586.5 KB
Camera: NIKON D7100
Aperture: F6.3
Exposure time: 1"
Program: Manual
Metering Mode: Spot
White Balance: Auto
Thanks for the advice/tip. I wasn't thinking at the moment. And yes, I was using a tripod. I'm extremely picky when it comes to noise... therefore I'm using ISO200... I'll definitely stopping down a few stops if there's a chance next time... Many times when I got home and uploaded the pictures to comp then realized that I should have done this and that... I guess this comes naturally with experience... And I have none...
Thanks.
Al,
EXIF Data
[PhotoME]
[Overview]
File type: JPEG
File size: 586.5 KB
Camera: NIKON D7100
Aperture: F6.3
Exposure time: 1"
Program: Manual
Metering Mode: Spot
White Balance: Auto
Thanks.
Al,
Hey Al,
With that camera, you should be able to easily shoot ISO 800 / ISO 1600 with no noise (as long as you get a solid exposure) and get good images all the way up to ISO 6400. That would give you a little bit more latitude on the shutter / aperture... and allow better shots. Sometimes a little noise is better than a lack of DOF, or movement blur due to camera or subject movement.
Green snake like Nagini which Lord Voldemort had in the Harry Potter series ! Looks deadly venomous ...
Thanks.
Al,
Oh man, You're not alone.
Anyhow, cool Viper pose.
The snake is a male Bothriechis rowleyi. I used to have one myself. They are constantly posing like this so it will be easy for you to redo this shot with better lighting and composition. I would recomend using a flash positioned bottom right of the image and pointing at the snake. I would also use a tighter crop and like others have said a greater DoF.
Here is a shot of a similar snake in a similar pose that I made- not the best image but maybe it will give you an idea of what you can do.
EXIF Data
[PhotoME]
[Overview]
File type: JPEG
File size: 586.5 KB
Camera: NIKON D7100
Aperture: F6.3
Exposure time: 1"
Program: Manual
Metering Mode: Spot
White Balance: Auto
Thanks.
Al,
Hey Al,
Charlie,
Thanks for the suggestion. I haven't shot anything over ISO800 yet. The noise is pretty minimal at ISO800 but it's there. I'm just picky... Maybe I should buy FF camera... I will definitely play around with different ISO. I remembered I didn't like how it turned out at ISO640... There's some noise when I zoom in 100%. I have to reduce the noise at Post Processing... I see your point though. Thanks.
Al,
Thanks. If there's another chance I will step down a couple stops to get better DOF.
Case in point: ISO 4000 on a D7000.
