also some say that, Bigger sensors require less resolving power of the lenses to be sharper.
Actually it's just the opposite..
every lens crops out a circle of light, if you use a full frame lens on a crop sensor, the crop sensor is using the center of the full frame lens, which is always the best part of that lens,
kind of cutting the crust off of your bread.
Full frame sensors are always using more of that circle of projection,
every lens drops a circle, the bigger the sensor the more of that circle it's using.
The further out it goes the worst it gets,
and it doesn't matter what lens from a cheap lens
or super expensive , like, leica or zeiss,
the further you go out of the center of the circle of projection the worst the image gets,
and another thing people think that ISO is connected to exposure, that is not true ISO is applied gain, if you don't believe me just look up the word iso invariance,
https://improvephotography.com/34818/iso-invariance/
people think of bigger sensors gathering more light like a window in a room, bigger window opening the shades means more light in the room, then if you open the shades on a smaller windwo,
but Sensors don't work that way,
it's per unit area...
People always things full frame gives you more light then smaller sensors, (NOT TRUE)
