Some math questions from you guys
MohaimenK
In between her...
70-200 2.8L would be 112-320mm if I was to use it with my T1i which gives me 120mm zoom over my 5dMK2. But if I was to get the 2x TC would that simply make it up to a 640MM at f5.6 (constant)??
My math says yes and hoping the camera works the same way.
would also like to know the answer to this
Your math is correct.
Auto focus may have difficulty with an effective max aperture of f/5.6. A 2x TC can also have a negative effect on overall image quality.
The image quaility will take a noticable hit - however whilst the original 70-200mm f2.8 IS L took what most considered to be too much of a hit with the 2*TC the 70-200mm f2.8 IS L M2 takes a far smaller hit and its image quailty with the 2*TC is comparable to the 100-400mm L (from tests I've seen the 100-400mm has a very slight edge, but its so slight that you can't tell them apart - esp from a print or websize shot).
Eg: Original lens with 2*TC
little birds photos test - a set on Flickr
New M2 lens with the same 2*TC (M2 version of course)
Minsmere - a set on Flickr
In my experience I used the original with the 2*TC a about 2 or 3 times in total - whilst the M2 I'm quite happy to let the 2*TC sit on the lens as long as I need the range without any image quality worries.
PS - please note however that if shooting wildlife the animals will take into consideration your longer focal length and thus move that much further away from you - many think that they've a contract with canon to keep doing this until you get a 600mm or 800mm L lens ;)
Your math is correct, but as others said, the image quality will be reduced probably more than you'd like.
Thanks guys, I was looking at the new 2X TC III
I guess if it's too much then I can always pull out the 5d2 and shoot at 400MM which I believe I posted looks VERY good. (below). Granted this was shot through the dirty store glass window which is tinted.
Shot at f5.6 at 400mm with the 70-200 2.8II M2 with the 2x III TC
