Ted Evans
- Joined
- Nov 29, 2014
- Messages
- 177
- Reaction score
- 22
- Location
- Crossville, TN
- Can others edit my Photos
- Photos OK to edit
Hello all,
I am totally ignorant about speed lights and looking for some help/suggestions. I have a D7100 and a SB700 that I would like to use off camera. I also have an old SB25 that I would like to use if; it will work with what I have. My thought is the SB25 will have to be used in the manual mode. My question is, will the following equipment accomplish what I want to do without requiring a degree in Quantum Physics? I have played a little with Commander mode in the camera but do not like the way it works….which could be due to operator error. The problem is, there is a few seconds delay from the time the shutter button is pressed to the time the camera operates and the flash fires. If this is SOP, then it will not work for what I want it to do, what say you? Thanks for your comments/opinions.
YONGNUO YN-622N 1 x TX + 2 x RX i-TTL LCD wireless flash controller wireless flash trigger transceiver DSLR for Nikon
http://www.amazon.com/YONGNUO-YN-62...8-11&keywords=yongnuo+trigger#customerReviews
