Spooky pinhole
gsgary
Chesterfield UK
Mamiya c330 + 135mm lens with element removed and pinhole fitted
Ok, I'm normally not a pinhole kind of guy, but this is awesome.
Is this a film sensitized to record ectoplasmic vapours ? If so, sell the idea to Ghostbusters. :1219:
I met Ghostbusters some time ago.
Nice!
not quite understanding how you did this, but this is spooky in a real way awesome.
Pinhole magic ;)
Getting better at the pinholes, Gary! :thumbyo:
Pinhole magic ;)
Thank you just need to try and get better focus, not sure if moving the bellows in or out will affect focus ?
Pinhole doesn't have "focus" to work on. :1247:. The pinhole image is always "in focus", but never truly sharp. You can work on the sharpness; smaller pinhole and, OK, bigger distance from the hole to the negative. (That will off course affect the angle of view.)
Bellows, as timor says, will mainly effect field of view. Also, of course, effective f-stop. The C cameras should give you some nice control with their crazy long bellows, just be sure to increase exposure as you rack out.
The camera might even have a calculator you can use with a little thought. Possibly it doesn't matter as you're in the land of reciprocity failure anyways.
