Stops of light explanation
SethAlbritton
north carolina
I understand somewhat but not fully.
F1.4 to 1.8 is a stop correct?
If so what is a stop above 1.8?
Also F1.2 is a two stops below 1.8 right?
1.4 to 1.8 is only slightly more than a half stop.
1.2 to 1.8 is one stop.
Thanks for the help but lets make sure I still understand this
1.4-2 is a stop
2-2.8 is a stop
4-5.6 is a stop right?
Now with shutter speed
is 1/30th to 1/60th a stop
100 to 200 a stop?
Now with iso
200 to 400 a stop?
I was under the impression that when you doubled the number it was a stop, but I wasn't talking with experts either.
Thanks for the help too
you got it! A factor of 2 -- twice as much/half as much. In the case of the lens f/stop: f = focal length / diameter of iris opening = f/stop number.
Joe
P.S. And since they're all stops they can all be interchanged without altering exposure. Add a stop with the shutter and take away a stop with the iris and exposure is constant.
3.14152653897923842643832750288.
1.73.
299,792,458
1, 2, 3, 5, 8, 13, 21, 34, 55, 89, 144, 233, 377, 610
No fair! I was gonna do the Fabonacci Series!
Then do it with a photo:
photo by: Flickr: lucapost's Photostream (CC license)
Joe
1.4-2 is a stop
2-2.8 is a stop
100 to 200 a stop?
Now with iso
200 to 400 a stop?
A stop is the doubling or halving of the light. For ISO and shutter speed the number used for the value can be halved or doubled, but aperture is different.
Aperture f/numbers represent the ratio of the AREA of the lens opening to the focal length. Since it's an area, you can't simply double the number and assume that is equal to twice the light. In fact, if you double the number you're actually quadrupling the light. Turns out that to double the area you multiply the f/number by the square root of two, which is roughly 1.4.
But here's a trick to help you remember. The square root of 2 times 2 IS 2. So that means every TWO stops of aperture DOUBLES the f/number. So if you can remember a couple key values like f/1.4 and f/2, you can extrapolate the rest of the values by going by two stops at a time:
1.4, 2.8, 5.6, 11, 22
2, 4, 8, 16, 32
Eventually though, you'll know them all by instinct anyways. :)
No. Doubling/halving the number means a two-stop difference.
Doubling or halving the shutter speed values and ISO values is 1 stop. That doesn't work with the lens f'/stop values. Think about the diameter of a circle. If you double the diameter of a circle it's area increases by 4.
Joe
