zsteph07 said:
For my daughters baptism... I have a Nikon D3100 and standard lens and also a 200 mm lens ... Inside the church while and after the ceremony
zsteph07
I mean to how to set it up... Shutter speed and aperture .. Iso or Wb .. Im having trouble with that and all kinds of indoor light
zsteph07
"Standard" could be any one of several "kit" lenses, but I'm guessing you mean the 18-55 f/3.5-5.6.
As far as I know, there are only a couple of fixed focal length 200mm lenses for Nikon. One is an f/2.0 and the other is an f/4.0. The f/2.0 is a $6k lens. The f/4.0 is a $1,600 lens. If you've got either, it's the lens you'll want for during the ceremony.
I'm guessing, completely by the nature of your questions, however that those aren't the lenses you have. I'm guessing you have another variable aperture zoom that goes to 200 (like the Nikon 55-200 or 18-200).
Assuming your choices are the 18-55 or the 55-200, you're most likely going to want the 55-200 for during the ceremony and the 18-55 for after.
Depending on the church, you're probably going to want to shoot at ISO 800 minimum, and might need to go as high as 3200. I don't have personal experience with the D3100. I think you'll seeing noise in the images at 800, getting rough at 1600, and be fairly nasty at 3200 without post-processing noise reduction. Again, though, I don't have personal exp with that camera.
If you're comfortable in manual mode, shoot at the slowest shutter speed you can. Use a tripod or monopod if its available. Use the widest aperture your lens will allow for whatever focal length your at (i.e. f/5.6 at 200mm).
Shoot RAW and leave white balance in Auto.
If budget allows, consider getting better lens(es). Look for constant f/stop zooms like the 24-70 f/2.8 or the 70-200 f/2.8. Those are very pricey. If budget doesn't allow for that, look at the 50mm f/1.8G for about $200 or the f/1.4 for $450. You'll need to get close, but you'll be able to shoot much lower ISO.
