Switching back & forth between PS & Raw
linda_o
Midwest
Hi,
My typical workflow:
Open .dng in Bridge to Camera Raw
Edit in Raw
Open Image in Photoshop CS4
Edit in PS
Question: Can I flip back to Raw, do more editing, then flip back to PS?
I read somewhere that you can click on the layer icon in PS to toggle back to raw, but this is not working for me.
Thanks for any help, advice!
linda_0
When you're in ACR and you go to open the image in Photoshop hold down the shift key; the Open Image button will change to Open Object. This will give you a Smart Object in Photoshop and allow the process you're referring to.
Joe
Welcome to the forum.
Joe is right. To do that, you need to open the file as a 'smart object'.
Thanks for the quick response. I see how I can do that if I do not edit the photo. However, I would like to work on editing - dodging, cloning, etc., and to do that, I have to rasterize the layer. Then I can't switch anymore.
Does it work if you do you dodging, cloning, etc, on separate layers?
Yes - but . . .
This is getting complicated. Maybe I need to go to square one with a book on layers, and I don't know enough about how to work with them. If I create a duplicate layer, and work on that, I can make my edits. But I have to go back to the unedited layer to flip back to raw. I go ahead and edit it, then go back to PS, but now my old edits don't apply to this adjusted picture. I would have to duplicate it again, and start my edits all over. Right?
(if this needs too much more tutorial - maybe I just need to be pointed to a good book?)
