Hello!
Trying to make this hard decision, hope you guys can give me some insights.
Tamron 60mm f2.0. minimum working distance 10 cm. ~ $500.
Tamron 90mm f2.8. minimum working distance 9 cm. ~ $500.
I have a d7000 and I wont be upgrading to FX anytime in the next 5 or so years. So the tamron 60mm DX form factor is not an issue.
I will be shooting macro wildlife. I know I should be getting something with longer working distance but I just cant afford it right now. This will be my first macro.
Apparently the core difference is the better optical quality from tamron 60mm. Some people say the 90mm's extending barrel is a downfall but I havent concluded that so far. From another perspective, when the barrel extends, you would actually get more distance from the subject cause your body would be farther away from the subject, thus reducing the bug's fleeing chance.
Also, I will be using the built-in flash so Im not sure which one is best in that matter.
Thank you guys!
Thank you guys!
