TE-06 Aluminum Alloy 3-Sections Camera Tripod
Link Delight Online Shop
Official Vendor
Supporting Vendor
Features:
  • Monopod: This TE-06 Aluminum Alloy Tripod have an extra function, all the legs can be removed and used as monopod, it is light and convenient, also give you other choice, also save the space
  • Leg Section Locking System: this will save more time and without the struggle of loose or rotating leg sections while locking or unlocking the leg section.
  • The knock-down centre column :
    1)centre column and locking system institutions to height adjustment more convenient, which can ensure stability
    2)The centre column is consisted with two columns, when you want low angle shot, you only need to remove the long one.
    3)centre column can be using upside down, inverted to shootor or photography work,
  • Plucking Angle Adjuster : Simple but useful plucking angle adjuster can adjust to the wanted angle easily. There are three angles , high, middle, low, allowing free adjustment according to actual needs
  • Centre column locking System: The Alloy Tripod offers two locking knobs to lock the centre column, pls see the above picture.
  • Closed Foam Grip: it will give you firm and comfortable feeling, especially in cold days, this cold resistant grip act as an insulator between the cold tripod leg and your hand.
  • Interchangeable Feet : This tripod can be configured with either screw-in rubber feet or stainless steel spiked feet to meet the needs of your shooting locations and conditions.
  • 1/4” or 3/8” screw with centre.
  • Tripod bags : Bags are made of top quality materials, providing good protecting to your tripod and head.
The price : $104.99
more details :
TK-254 Aluminium Camera Tripod + Ballhead Kit
US$95.99
Triopo B-2 Photography Ball Head for Gitzo Manfrotto
US$66.99
Triopo B-3 Ball Head for Gitzo Manfrotto Induro
US$78.99
Fotopro C4i Tripod w/ Ball head Photography Set Pink
US$107.99
Fotopro C4i Tripod w/ Ball head Photography Set Titanium
US$107.99
Fotopro Camouflage Tripod FLA-584G w/ Ball head Photography Set
US$96.99
