- Joined
- Dec 9, 2006
- Messages
- 24,024
- Reaction score
- 16,365
- Location
- Somewhere in Maine
- Can others edit my Photos
- Photos OK to edit
- Thread Starter 🔹
- Moderator 🛠️
- #17,206
Yeah - some are worse than Mardi GrasBoobies? At a tractor show?
Relax! He'll post his photographs.I HATE YOU!Good morning Hosers. Off to threshers show today, over 1000 to see. Pretty pumped, this is a good one in Wauseon, OH. National Threshers Association, Annual Steam Traction Engine Show
The only thing you'll miss is the smoke, the sounds, the people, the concession stand food, being able to take your own photos, and a sunburn. So it's all good.
Yup, check all of those except sunburn. Perfect day, so much to see. I got some good pics. Corn dogs, fried Bologna sandwich, ice cold beer, and lots of steel, smoke, steam, and boobies.Relax! He'll post his photographs.I HATE YOU!Good morning Hosers. Off to threshers show today, over 1000 to see. Pretty pumped, this is a good one in Wauseon, OH. National Threshers Association, Annual Steam Traction Engine Show
Omg I drove in my driveway parked my truck got out and noticed there was a fire in the truck bed I pulled out the brush that was burning let it finish burning in my driveway and the rest of the little fire left in the bed went out with some stomping . I think I figured out where my cigarette ash went when I flicked it driving. Did I mention my truck leaks gas too and sometimes it don't stop the wheel bearing sensors aren't reading so the antilock kicks on and sticks? I really need to change the hub unit(s) . Other day it got stuck in neutral so I put on the ebrake climbed under it noticed the shift cable was off again . Manually put it in park so I could start it climbed back under it then manually put it in drive got in and drove home. Sad to admit but not the first time it's happened this time I put a bolt through the shifter cable holding it on shouldn't go anywhere now. Lucky the truck didn't roll away that coulda suckedThat's not necessarily (in fact probably not) the result of not having the discs turned, 'though it could be. It could be an indication of front spindle wear, pad failure, wheel bearing wear/failure, or disc warp as a result of hard breaking followed by cooling (stomping on the breaks and then driving through a puddle). Regardless of the cause however, this is NOT something to ignore. Your front breaks typically provide 60% of your stopping power, and when they're "chattering" they provide VERY little stopping power, possibly as little as 20%.Morning, hosers! I hope everyone's hump day is going well so far.
On the subject of old cars, my 2001 Civic with about 197K has front brakes that chatter, result of not having the rotors ground down last summer when it got new pads. I didn't figure on having it very long, but now it looks like I may keep it until early next year. The chatter is getting a little worse (happening at lower speeds and a little more pronounced). Am I in for some sort of brake catastrophe soon or can I ignore it for a while? The car doesn't get much mileage, probably only 3K/yr at this point.
