The Coffee House
My election results prediction:
"Meet the new boss; same as the old boss." --Won't Get Fooled Again, The Who.
Excel - just make a macro of what you just did and set that up for doing all 26 tabs next year. Put a button that says EASY to run the macro and you're all set.
But, I would rather have all the data in one table (that is set to let you filter by any column so you could see totals for any filter applied to any of the columns). Then I would throw all that data into a pivot table on another tab where you could look at whatever anybody asks for.
I mean, just in case you didn't have anything else to do this weekend.:1247:
Thanks for the suggestions. First, I have to figure out what a macro is and how to do one :)
As for the second suggestion, so you're saying that I should have all the pay periods in one massive table? I'm not sure that's going to work. It's more than just hours for each pay period - I'm also tracking the hours worked at different sites and for different accounts (grants). Trying to put all that in one table 26 times seems like it would get unwieldy, no? Plus, I also don't know what or how a pivot table is :048: As I get better at Excel (and more used to tracking payroll), I might eventually understand this approach better, but for the moment and for my current sanity, I think I'll keep my separate tabs.
But I am thankful for the information steering me in the right direction! :)
Hey, hosers!
I was thinking about this last night.
You could likely get real technical, get into macros or VBA, but I think a very simple approach would be best for a first iteration of this spreadsheet.
Asking the more Excel-technical minded for help is like asking a photographer to take a photo of you. Sometimes you just want a snapshot, not a portrait.
My suggestion would be to simply reference the other sheets, then drag using the autofill function at the bottom right hand of the cell (assuming all totals from the other sheets are in the attaching cells). See the image below as an example. The formula has an apostrophe in front of it to show the reference; the actual cell value should not have this apostrophe.
Not sure if this would work with your file, but it would be pretty easy. Otherwise, you may be able to use the VLOOKUP function, but again, it depends on how the spreadsheet is set up.
So it begins....
In other news, here are the ads at the bottom this morning:
Seems like be Ads like this thread ;)
There's a National Payroll Week? Oh for heaven's sake.
Buenas Dias Coffee Hosers. Another gray and cool morning. There has been a lot of activity yesterday and this morning at the front Hummingbird feeder. Gary's pull down projection screen came in yesterday. He is planning to install it in the house for easier indoor viewing.
In baseball news:
Bottom of the ninth, two outs and Moore has a no hitter in his back pocket when Seager barely punches a single into right. That gots to be painful. That single is almost as good as a win. Sadly, the Dodgers traded A.J. Ellis for Carlos Ruiz. Gary doesn't get it. Ellis and Kershaw are BFFs. Why, so late in the season, would you want to risk upsetting the best pitcher on the planet for another catcher that is only slightly better at hitting lefty's? They're bums ... they should neverah had left Brooklyn. :(
Jon- You need to up your pen game. (See Snowbear)
I stepped it up a little bit this year -- the pen is a Pilot Metropolitan, a fountain pen for beginners and for people who lose them (or people who work with kids, like me).
I bought two -- one for normal writing and one for marking papers. If they last the year, maybe I'll upgrade.
Not good enough, see Snowbear. :cool-48:
With your payroll spreadsheet, Gary would have bet dollars to doughnuts that you were a card carrying member.
Hey man, I'm new at this payroll business. I still consider myself a professor! And technically, I still am, but just not only a professor :D
I grade with pencil (though I do write the grade in pen.) I've learned that I get much less stressed when I know I can erase and re-write a comment if I change my mind about how I write it. I don't do this often, but when I wrote in pen, I would agonize more than I should over how to write the comment and that would make grading more stressful and time-consuming. With a pencil, however, I can write something, anything, knowing that I can go back and edit my comments. If I know I am going to, I'll write lighter. If I know it will be fine, I'll make darker pencil marks. That way if the student erases the comment, it will still be clear that something had been there. But honestly, I don't worry about it. The ones who read the comments are actually interested in improving, and the ones that don't can't be bothered to go through the trouble.
I don't use just any pencils, either :) I use pencils that I get here: CW Pencil Enterprise
