The Coffee House
Or hand the project off to a grad ass??
First, there are no grad students at a community college, so can't do that ;) Second, I couldn't do that anyway since I'm low on the staff totem pole (even if I am high on the adjunct totem pole).
Finally, and most importantly, I am a very stubborn woman and I refuse to not figure this out! :D
Gary's/Todd's way is doable, but tedious. You'd have to reference each sheet individually. I do believe there is a way to do it automatically, and I'll look into it tonight. I used to write macros and VBA, but it's been so long since I've done that... :cower:
Oh too bad if you can't pawn it off on someone else, I never could or did either but it sounds good. Just put it on graph paper and scan it in. Make sure you add some cats and rainbows and unicorns.
I'm a little rusty, and I'm sure there's an easy way to do it. I have a couple of questions:
  • Are all the weekly tabs already created or are you creating new tabs as each week goes by?
  • Are you trying to sum these values between weeks automatically, or are you trying to show them in another sheet automatically?
  • Is each pay period sheet the exact same in layout?
Weekly tabs are already created and they are in the exact same layout. I even set up the AutoSum formula for the totals row. They just don't all have data in them. That gets entered as we go along through the end of the year.
The AutoSum formula takes care of the sums in each tab. I was hoping to just take the totals row from each tab and enter that data into a new table in a new tab and have that populate automatically as I enter data into the tabs.
I'm getting a headache from trying to remember this stuff. So nasty. So cruel.
But it's doable, if I'm following you correctly. If all you're really doing is taking the totals row over to a new table, it could be just a question of how to apply a copy & paste. You can select & copy the row of totals, and when you get to the new table, over the cell you want to start your paste, right-click to look at your paste options. There are times you may only want to paste the sum you've copied, but it sounds like you may want to also capture the embedded formula. You'll see those options listed and it will make a difference on how you can work the data, going forward.
It's been a few years for me, but I was in Excel daily and didn't do anything that required more than basic/intermediate skills. I had tons of weekly/monthly/quarterly reports and moved data as I needed in a similar fashion as outlined.
I'm starting to break out in a rash now, just thinking about it. eww.
Try this. Wait for it, 25 seconds in read the label. Look at the soothing blue water... look a crown! and a water droplet shot...
OK that's enough of that, not waiting for the end if there ever is one. Fast forward, another crown, more water droplet photography, more cool blue waves... what kind of advertising is this anyway??
You are totally in my brain right now! :)
There's probably an easier way to do this with more data, but I just figured out that I can do it by copying the totals row and then pasting the link into the new table in another tab. It's only 10 tabs at this point. Next year, it will be 26 and I might want a faster way of setting things up (of course, copying the entire worksheet and then clearing data and adding 16 new tabs might be one way...).
But either way, I think I've got it set up. And if I do say so myself, I'm quite proud of it :)
Oh too bad if you can't pawn it off on someone else,..
That's probably a bad idea even if the other person knows how to do it. The one thing they will probably NOT know is how it's supposed to look in the end.
I would not want someone else to build my spreadsheet if I could do it myself with some effort.
There's clunky that sort of works (after a fashion), and then there's elegant that is efficient, fast, and pretty.
Well, then that's the best outcome, isn't it? It's actually a great program and can make your life much easier - or drive you nutty when you're trying to make it do something that you KNOW can be done. I've had those proud little *ah HA!* moments, too. You teach yourself something and it's rather empowering - so, you know, yay. :1247:
