Tell that to the tightwads that won't fix the roof.You should replace them with a T-8 LED retrofit kit. They will never need replacing for 25 years and you’ll save bunches of money paid out to the power company.I do believe I mentioned that these are 48" T8 bulbs. Insert and half twist. If they had them I suppose I could replace the bad ballasts as well.
As far from programming as one could get. It is somewhat amazing how many dark fixtures are now lit up again.
Almost gotta wear shades in the produce department. The other end of the store may be a bit harder with more dead ballasts.....
Both. The 23 f2 is an excellent lens. Close focus, just right field of view, super micro contrast, instant AF, short focus throw if using manual, no distortion. The only negative I can think of is CA wide open on chrome surface edges when close up shooting. I trust most non macro lens would exhibit that behavior. The B & W images this lens can produce is impressive. It's right there with the 16mm, 35mm 1.4, and 60mm in terms of micro contrast for b & w photography.Should I buy a used X100T or a 23mm f2?
I returned the 23 f/2. It was fine but nothing special. It didn’t really do anything the 18-55 couldn’t do.
Yes.Should I buy a used X100T or a 23mm f2?
