Pretty inspired piece of photography. A bit of analysis
The upward-pointing open rectangle formed by the armchair arms and seat is reflected in the similarly shaped rectangle of the door, with the darker chair balanced diagonally against the bright door center. The narrative here is past to future (or present, if you believe in the rapture).
The slightly grimy-looking and tawdly corner is contrasted by the near-featureless brightness of the door, again echoing the theme of past life, present rapture.
The high-key upper right side really works well with the mid-key lower left as a visual balance.
The diagonal of the floorboard to the left of the chair again suggests movement, from left to right, from the chair to the door, reflecting the previous impression.
So there are a number of elements that reinforce each other and work to a common theme, much as individual instruments in an orchestra blend into the overall score.
Well seen, well captured.
