Lake Hemet is not fed by the Salton Sea is it? Nice shot and video. =]
Just out of interest what type of power (assuming you have any fitted) do you use? Our Motorhome has both gas and 240v hook up electric as standard. We mainly use the electric and I bought a generator for 'off grid' travel. The gas gets used sometimes but we don't use it for heating, water or shower etc.
It's primarily solar. I have 300w total in solar panels charging a 100ah lithium battery. The entire trailer is wired for 12v with 12v and USB plugs. I do have a 1500w inverter in case we need to use AC appliances. I also have a Honda EU2000 generator as a backup. We use propane for cooking and heating. There's also a tankless hot water system. I ran pipes underneath so we can hook up a shower hose to any of the corners if we want to just take hot showers outside.
Thanks. That sounds and excellent set up.
I should have said all our lights are 12v LED's which run off the leisure battery, which is in turn is charged either by the mains hook-up, generator or engine when the thing is being driven.
I don't have any solar but should really consider something.
You must be chuffed with your results. It looks quite unique too and I know you're gonna have a ball touring and camping in it. Well done.
Photos are nice!
Are you in the Inland Empire? near Redlands?
Salton Sea is a fascinating place indeed. And a portable home works well...
