JWellman
- Joined
- Oct 20, 2010
- Messages
- 705
- Reaction score
- 90
- Location
- Indiana
- Can others edit my Photos
- Photos OK to edit
Hey everyone...My apologies in advance for the length of this post!
Im trying to work with using Bokeh in a dim situation but I have no idea what Im doing. I took numerous shots last night using different f stops and ISO ranges just to see what I could come up with. After seeing DBJs photo I wish I had used more mini lights (Post #637 Click here to see his set up).
Last night I was using the Canon 85mm lens - f3.5, 1/100, ISO 400. Unlike DBJ I hung my lights approximately four feet behind the bottle on a black drop cloth. Comparing to DBJ, I also lacked the use of a softbox. I do not have one, nor have I tried to create one. Looking on line I could probably make one using the equipment I have.
I want to try the shot again but was looking for a little help first. I only used one light on the bottle and feel certain I needed more. My husband bought me a starter lighting kit back in June but I havent played with it much. I do have two other lights though. I was tired last night and it was late so I basically gave up on the project.
My biggest frustration is the lighting and what Im supposed to do. If I created too much light, or increased the ISO, I could see the backdrop and strands of lights in the background which wasn't correct. Increasing ISO also caused the bokeh to be overexposed. If I decreased the ISO then the bottle was under exposed. The bottle and glass are also too soft, probably due to lack of lighting or motion on my part.
I want to try this whole set-up again. Can you guys offer advice? I have other lenses but didn't try any of them. Perhaps the 50mm would work better? And also, what shape should my bokeh be if done correctly? With this image I see hexagons beginning to form but I'm not sure if they are as sharp as they should be.
And just so you know, if you ask a question and I dont reply, Ill be back this evening. I wont go into all the long terminology but in a nutshell my husband had a stroke in his right eye this past weekend.
He lost a significant amount of vision and we will be with specialists the majority of the day.
Jess
Jess
