UMass Lowell @ UMaine hockey (x11)
Trenton Romulox
Maine
One:
Two:
Three:
Four:
Five:
Six:
Seven:
Eight:
Nine:
Ten:
Eleven:
Thanks for looking.
Comments and critiques are greatly appreciated.
Peace.
they are really great shots, where were you sitting??
on a technical note though, they could be even better with the right white balance, needs to be brightened up a bit for a more natural color, too blue right now (shouldnt be a tough fix if you shot them in raw...)
instead of a tungsten white balance (Seems to be what its doing right now), maybe something a bit warmer/brighter?
I was up at the top of the bleachers in the arena. And yeah, the brightness is a compression issue. But the white balance, well, that's all me, haha. I was shooting at a custom temperature but it wasn't warm enough. I could just batch all the shots and warm them up a couple hundred degrees. Do you think that'd make a big difference?
Thank you very much for your comments. They are much appreciated.
I would add a touch of warmth to the white balance, and notch the exposure 1 stop up to compensate for the ice throwing your metering off...should all look excellent and white!
was curious what settings you were using and what cam/lens?
(ive been toying with hockey shots as well lately...)
Nice pics, especially 7 and 11..
I find that the easiest way to get the white balance right is to shoot a spot on the ice and use that for your custom white balance setting. I also have a grey card that I use depending on the situation. Its unbelievable what a difference the correct white balance can make in your photos and how it can make your colors pop. I shoot a lot of hockey so I usually play around a bit till I get the right color balance. Nice shots though.
