Use built in flash to trigger external flashes?
matseski
I have a wireless reciever that can also be triggered by light. Is it possible to trigger it with the Canon 50D's built in flash?
I have been playing with it for a while but the preflash has bee causing me problems. Is there a way to disable it?
Thanks
yes, if the trigger is also an optical slave it can be triggered by the built in flash. you need to turn the pre-flash off and you'll want to set your camera to a BIG negative FEC. In order to turn off the pre-flash you will need to go to your custom function 3 menu. It's # 5 on the C.FN III menu on the 50D.
