TCampbell
- Joined
- Mar 31, 2012
- Messages
- 3,614
- Reaction score
- 1,558
- Location
- Dearborn, MI
- Can others edit my Photos
- Photos OK to edit
There are a *few* of Canon's L series lenses whether Canon's manual will tell you that in order to "complete the weather seal" you have to thread on a front filter -- they don't care which filter. But this is only IF you are actually trying to use the lens in an environment where having a weather seal is important (and how often do you actually do that?)
Otherwise... the only filters you need are the filters that actually do something useful (like polarizers, neutral density filters, etc.) UV filters just block UV light. The problem is... the camera already has an internal filter blocking the UV light. A VERY high quality UV filter will actually block _most_ of the UV light and will block almost _none_ of the non-UV light. A VERY high quality filter will also frequently have anti-reflective coatings to reduce the possibility of flare and ghosting caused by the filter.
A cheap UV filter won't have any of those things... many cheap filters don't actually do a very good job of blocking the UV light (even though that's supposed to be their primary purposes -- but I guess it doesn't matter since the camera already has a good UV filter built-in) but what they MIGHT be doing is actually blocking some of the visible light and worse... blocking the visible spectrum in a non-uniform way (which creates a color-cast on your images.). And then of course there's the deterioration to the optical quality and possibility of flare and ghosting.
The bottom line is: You probably don't need ANY "protective" filter unless you happen to own one of the very few L series lenses whose documentation states that a filter is required to complete the weather seal. A filter won't do much to help. And while a really good filter probably won't degrade your image quality in any noticeable way... a cheap filter certainly will.
You bought a high-end camera and high end glass so you can take high quality images. Why would you throw a cheap piece of glass into the image path that reduces the quality? If you buy a filter, buy a GOOD filter. But I'd suggest only buying filters that perform a useful function -- not a UV filter.
