jeremyamayora
- Joined
- Nov 27, 2011
- Messages
- 48
- Reaction score
- 1
Does using a UV lens take away from the quality of the photo.
UV/Haze filters are used to remove the haze from UV rays that the human eye can't see, but the image sensor can and can dull your images a little bit. Because of the minimal impact on the images many photographers use them to help protect the lens as well. Some say the UV filters degrade the image because you're adding another piece of glass and shouldn't be used all the time. I disagree, the degredation is very minimal and most of the time, not even noticeable. The most expensive UV filter I've bought cost $40.00. The cheapest lens I've bought new cost $100.00. UV filters will always be cheaper than buying a new lens. Keeping a UV filter on all the time will protect the front glass element of your lens from scratches and stuff. The glass in UV filters also breaks a lot easier than the glass in your lens. This is important because if you drop a lens the UV filter glass will usually break first, and that breaking of the glass absorbs some of the shock and helps prevent the glass inside your lens from breaking. I had a mishap once where my entire camera bag came undone while riding a horse at full gallop. Camera, lenses, flash, everything fell out onto a rocky road from 6-8 feet while also traveling about... however fast a horse can run... $80.00 in UV filters saved over $2,000.00 in lenses. All of my UV filters were broken, but the glass in the lenses were just fine.
Protect from what?I did mean filter sorry about that. I was told by a local shop to always us one to protect my lens. But I thought it would down graded my image
Check out this article from a lens rental place............LensRentals.com - Front Element Scratches
And this YouTube video.
Actually, that was sort of true for film (they don't "remove haze from UV rays", they block UV light), but digital image sensors are not sensitive to UV light, so it doesn't do anything in that respect, unless you're shooting film still.UV/Haze filters are used to remove the haze from UV rays that the human eye can't see, but the image sensor can and can dull your images a little bit.
"Minimal impact on the images" tells us that there is some impact (read: degradation of image quality) on the images. How much depends on the quality of the filter and the conditions at the time of use.Because of the minimal impact on the images many photographers use them to help protect the lens as well.
The very sentence structure indicates that some degradation of the image always occurs with the use of filters, even if that's "minimal". The sentence structure also tells us that "most of the time" it's not even noticeable. Well, that means that "some of the time" it is indeed noticeable.Some say the UV filters degrade the image because you're adding another piece of glass and shouldn't be used all the time. I disagree, the degredation is very minimal and most of the time, not even noticeable.
Unless shards of glass from a breaking filter flying toward it damage it, of course.The most expensive UV filter I've bought cost $40.00. The cheapest lens I've bought new cost $100.00. UV filters will always be cheaper than buying a new lens. Keeping a UV filter on all the time will protect the front glass element of your lens from scratches and stuff.
That's because it's not made to protect anything, including lenses.The glass in UV filters also breaks a lot easier than the glass in your lens.
http://www.thephotoforum.com/forum/...ed-nikon-d700-camea-lens-saved-uv-filter.htmlI had a recent mishap with a drop and (I Feel) the UV filter protected my lens (See my other posts).
KmH said:Protect from what?
YouTube Link: http://youtu.be/vzOLbMPe0u8
