nerwin
- Joined
- Jan 31, 2015
- Messages
- 4,355
- Reaction score
- 3,194
- Location
- Vermont
- Can others edit my Photos
- Photos OK to edit
A few years ago I purchased the Vanguard Alta Pro 263AT with the SBH-100 ball head and its been great until like last year when the head started to leak, the rubber grips deteriorated, quick release plate knob is loose. I'm really bummed that I spent a decent amount of money on a nice tripod head and its like falling apart.
As the SBH-100 is NOT a fluid head, it only leaks from the base of the head and its like some sort of grease or lubricant, probably for the head to rotate smoothly..now I have heard of others complaining about this issues and some that never had this issue..some say they might have put too much lubricant or a seal has dried up or something. Being that its so close to the adjustment knobs, it gets on my fingers and then onto my camera if I don't take a paper towel and clean the base of the head almost every time I use it. It gets worse if its laying on its side, but I'm just thats just because of gravity so I've been keeping it up straight which seems to help.
Now I know Vanguard has limited lifetime warranty, so I'm sure I probably could get the head replaced for nothing..but I'm wondering if I should buy a different head. I thought about the GH-100 pistol grip head, but just don't know if its something I'd like, it does seem easier to adjust, but also makes it seem to be even more wobbly because its much higher than the traditional ball head. But I have thought about getting the SBH-250 which is a fluid ball head and just an overall higher quality tripod head.
If you have any ideas for a good tripod head replacement that you know will work with my Vanguard Alta Pro 263AT, please let me know!
