- Joined
- Nov 27, 2011
- Messages
- 7,716
- Reaction score
- 4,577
- Location
- St. Louis
- Can others edit my Photos
- Photos OK to edit
The red rose is to bright you can't see the detail. it happens mostly to my photos when the subject closeup is red.![]()
Your red rose problem -- I can help. You have your edit tag set to NOT OK -- change that and I'll show you what's going on using your photo.
Sparky's note about the on-camera flash is important and it is a contributor but it's not the root of the problem. The red channel in your rose photo is blown to h*ll and the detail in the flower is destroyed in that process.
Here's an example of the same with one of my photos.
Joe
I have set the photo to allow edit the change in your photo is amazing.
First here's the problem with the rose photo:
I inset a histogram that shows what's happening. At the far right corner of the graph you reach the point of full saturation which is also the point of full loss of detail. The red channel in your rose photo is basically smeared all over the right side wall so that explains what your seeing and by the way good for you to have seen that and recognized it's a problem. Do a Google search for red rose images and you'll quickly find a few 100 thousand additional examples.
It's unfortunately a difficult problem. Once the damage is done it is either very hard and/or impossible to repair. Note in the histogram above that it's only the red channel that's shoved against the right wall. That means there is still detail in the flower petals in the other two channels. I was able to use that other-two-channels detail to do some red reconstruction but it's not the right way to do this. Breaking something first so you can fix it later is a bad idea.
Given the circumstance -- the best I could do.
So how did it happen and what can be done about it in the future is the question.
**As noted on-camera flash is a contributor and it exacerbates the problem. The photo I posted however had no flash applied and I still got the problem. Turn the on-camera flash off and leave it off.
**Your camera did it. The software in your camera is the culprit and when it created the JPEG file from the raw data it nuked the red channel. Your camera is not broken it just can't handle this. My camera did it too as you can see and they all pretty much do this which is why this is a tough problem. When you camera takes a photo the first thing that happens is the camera sensor records the data in a form that we call a raw file (go do some research). That raw file data is then processed into the finished JPEG photo by software in the camera. Go back and look at my photo. My camera made a real mess of it. The second version isn't, like yours, an attempt to fix the camera screw-up. What I did was have my camera save the raw data file and I processed that myself. Since I was able to do it (which means the data was recorded) I get to blame the camera software for not being able to do it.
**Two approaches: 1. You can learn to do what I did and save the raw data file and learn to process it yourself. Think really big learning curve, but hey why not learn to do it right! 2. We can help the camera software do better but in this case it isn't going to approach what you can do if you learn to do it yourself.
**How to help the camera software: In all fairness to my camera I did nothing to help it out with the photo I posted and so it really screwed up. Note in the camera version (left) how the photo has a blue/magenta color cast. That's the camera white balance taking a dive. The first thing we can do to help the camera in this case is set a custom white balance. Because you used flash your WB was good and in fact if you compare my camera did worse than yours. Your camera has picture controls for contrast and color -- got to use them in this case if you want the camera to do better. Lower contrast and color saturation in the camera controls. The next step is exposure. The camera is still going to botch these frequently if you allow the camera to take its metered exposure. Use the exposure comp. adjustment to reduce exposure some.
Joe
