Wacom settings question
JClishe
Cincinnati, OH
I'm trying to add custom settings for Lightroom in the Wacom Tablet Properties tool. It works fine for the Grip Pen settings, but when I select "Functions" then add an application, Lightroom doesn't "stick".
For example, with the Grip Pen selected I click the + in the Application row. A window with my running apps appears. I select Lightroom and click OK. It returns to the Wacom Tablet Properties screen and Lightroom now appears in the Application row and I can assign custom settings to the pen.
However, when I select the Functions tool instead of the Grip Pen tool and follow the exact same process as above, when I select Lightroom from the list of my running apps, when it returns to the Wacom Tablet Properties screen Lightroom hasn't been added to the Application row.
For those that use a Wacom tablet, are you able to define application-specific settings under the Functions tool?
I've never actually even thought about this, but I'm going to try it this evening. Which tablet are you using?
Intuos 5 with driver version 6.3.8-3 on Windows 8.1.
I was initially on an older driver so I upgraded to the most current but that had no effect on my issue.
FYI I just watched the Configuring and Customizing tutorial here and it confirms that it should be able to do what I'm attempting. They specifically talk about customizing the pen, which I already know works fine for me, but the screenshots clearly show custom apps under the Function menu which is what I can't get working. So I'm not sure what's up with mine.
Video Tutorials | Wacom
