This is my biggest problem. I know RAW overrides WB so it's generally set to auto. Well I open my files in PS RAW and the WB is ALWAYS off so I adjust each image, but my eyes must be off too because I can't get it right! All the images look either too warm or cool. It there a way to make the WB accurate without assuming it looks ok? I can't give a client 15 different images with totally different WB.
TIA
Yes, good photography is quite a bit more involved than just point and shoot.
Have you seen this:
Understanding White Balance
Raw does not 'override' WB. Raw records the light as it really is. When an image is opened in ACR is opens 'As shot' with whichever WB you had set on your camera. With the camera set on Auto WB, it will change along with the major light source in each scene you shoot.
Unless you use a target that has a known color (like a quality gray card), your eyes will always fool you.
Our brains alter reality so that many of our expectations about color are met.
Another issue is mixed lighting. If you have two or more different colors of lighting in an image, only one light source can be fully accounted for with a WB adjustment.
Sunlight is not white, it's yellow.
Tungsten light is not white, it is orange.
Flouescent light is not white, it is green.
But, as I mentioned above, our brains automatically make adjustments in each of those lighting environments so red or white or any optjher color looks like we expect it to look.
Cameras can not do that. they have to be told what kind of light is illuminating the scene.
