- Joined
- Nov 27, 2011
- Messages
- 7,716
- Reaction score
- 4,577
- Location
- St. Louis
- Can others edit my Photos
- Photos OK to edit
I ended up buying the Affnity software and so far I'm enjoying it. Thanks for the help.
I didn't chime in earlier, but as Adobe is the "800 lb gorilla" of the photo editing world, you'll find just about everything is designed to support their software. Loads of software that can operate as a plug-in ... build those plug-ins for Photoshop & Lightroom.
But the downside to Adobe software is that you can no longer just buy it. Now you have to "rent" it by the year. I am frustrated that people let them get away with calling it a "cloud" model since the features needed to qualify as a "cloud" product are not present. They do not offer "service elasticity". I can not pay for the software when I want to use (at the point of value) and not pay when I am not using it. They act like you get to rent it by the month... but it isn't actually possible to rent it for a month. It's a subscription with 1 year terms.
I bought Affinity for my iPad (of all things ... I still don't own it for the desktop). I found that it's really pleasant to use. It does everything I would normally use Photoshop to do (it even knows how to open .psd files) but it's easier to use and frankly it seems to do a better job. I was impressed. And of course you don't have to "rent" it.
I have not yet found a non-rent version of digital asset management (something to replace Lightroom). Skylum makes a program called Luminar and they are positioning themselves as a Lightroom alternative. But the big "catch" is that they do not have digital asset management ... but claim they are launching this in 2018. I'm taking the "wait & see" ... I would only buy it if they had digital asset management (and it needs to be decent). But on the plus side... this is software you get to "buy" (and it's reasonably priced). It's not "rental" software on a 1 year term like Adobe.
I’ve been using Affinity for iPad ($19.99!) and so far I love it except for sharpening. Care to share your thoughts/steps for sharpening? I’ve been using the Unsharp Mask filter but I can’t get it to work as well for me as when I was using PSE11 Unsharp Mask feature. The values don’t carry over. Also there seems not to be a general “sharpening” tool outside of Unsharp Mask.
Not sure about the iPad version but the desktop version of Affinity can sharpen a photo using two methods other than Unsharp mask.
Both methods require than you create a duplicate Layer.
First: Under Filters/Sharpen there's an option for High Pass. Create the dupe layer and then apply the High Pass filter to the dupe. You'll have to experiment with different values -- try 14 as a starting point. You'll get a pretty odd looking gray ghosty outlined image. Change the blending mode for that layer from Normal to Soft Light and the image will sharpen. Adjust opacity for the dupe layer to taste.
Second: Under Filters there's an option for Frequency Separation. Create the dupe layer, select it and then select Filters/Frequency Separation. You'll have to add two values in the dialog that pops up. Suggest a radius of 3 and 75%. Lower the radius for less sharpening and raise it for more sharpening. Click apply and your dupe layer will be replaced by two layers one labeled High Frequency and one labeled Low Frequency. Delete the Low Frequency (middle) layer and the image will sharpen. Use the layer opacity slider to adjust the amount of sharpening.
Joe
