What setting should I use for photographing an indoor plant.
annamaria
Milledgeville, GA
I have a Nikon d5100, lens 18-55 and 55-300. I am assuming I should use the 18-55. What would be the best setting to use for shooting a Christmas Cactus? I don't have any lighting equipment etc just the camera and lens at the moment. Any suggestions? I am still learning.
AV, F/8, ISO 100, Auto white balance, evaluative metering (matrix for you Nikon people) on a tripod. Spot focus on the trunk of the cactus. zoom out to 55mm and frame it tight.
Thanks so much! Will try that and yes will post. Going to do it as soon as my Christmas break kicks in yay!!!
You have the built-in flash. After getting your available light shots, try it with flash. Find a translucent white card or a half sheet of typing paper. Hold it or tape it onto the front of the flash.
If you have the patience for it, find a white card that is not so translucent, and rig up a reflector above the plant (full sheet of typing paper). Arrange the reflector to bounce the flash up onto the typing paper.
My starting point is usually like Eric's, f8 and 1/125. I use the meter to determine if I'm getting the amount of light needed for a proper exposure. If you use existing light f8 probably wouldn't give you a lot of light, so open the lens as needed (smaller f stop number=larger aperture/lens opening). I don't like to go slower than 1/125 shutter speed unless I'm in low light and then I don't usually set it slower than 1/60 handheld (and make sure I'm braced and have the camera steady).
Indoors I usually start at 400 ISO (I use manual settings) and raise it as needed. If you try setting the plant outside I usually start at 100/200 ISO in daylight.
You could try sitting the cactus where some window light will hit it, or put it under/near a lamp (you could try a few shots, with existing light and some w/a flash; I don't use a flash often, I've done sports where I have to use the available light so I've learned how to do that). I've heard of something like Designer described, I know a photographer who uses a white business card stuck in front of the built in flash on camera but I haven't tried it.
Where you choose to place the plant, think about the background and how it all looks in your viewfinder. Or if you'll be taking pictures of it where it's sitting, think about your vantage point and which direction will give you a nice background and some decent light. The cactus should make for a nice holiday picture.
Thank you designer I will try out your suggestions With typing paper and will look online about rigging a reflector. :-)
Thank you vintage snaps for your advice as well and will try the settings and suggestions you mentioned. Can't wait till my break excited !
Thank you everyone so far for all the great advice. Love it here.
Notice what sort of light you have in different places at different times of day. For example, where I live, there are big picture windows that get really great light in the morning, but if I want to try a still life in that spot, I have to get it done early. The same exact spot won't give me the same picture in the afternoon. Try the shot of the cactus in different kinds of light and see which is the more interesting picture.
I will definitely take a note of that and try shooting at different times. Thank you for the tip.
Did your camera not come with an auto setting for indoor plants? If not they try this website for a few minutes to learn the relationship of Aperture, ISO and Shutter speed. Then you will be able to determine the necessary settings for your particular situation. The CameraSim Virtual DSLR Camera Simulator | United By Photography?
Not sure if you are referring to Aperture Priority but I have been reading info on Aperture, Exposure and Shutter speed, still learning and wanted to know what the many knowledgeable photographers here would recommend. I am not using the auto mode though I have used the P mode. Thanks for the link.
