What type lights and how much watt power is needed for light box (tent)?
no1texan
Houston
I am making a light box/tent out of 20 x 30" white foam boards. The dimensions are:
Height 30”
Width 20”
Depth 20”
On each side the openings are 9” wide and 18” tall covered withwhite muslin fabric.
The opening on top about 12 x 12” also covered with white muslinfabric.
At the moment for lighting I am using Philips 23-Watt(100-Watt) Energy Saver Compact Fluorescent Warm White (3500K) Light Bulb (E*) fromHome Depot in a 60 watt desk lamp with a flexible neck. Does not appear to be puttingout much inside the box.
What kind of lighting should I be using for this size box/tent?
Most of my objects will not be this tall, mostly12” and under. But I have one item that is 24” tall therefore I made the box 30”tall.
Should I cover the front with the muslin fabric with just enough room for my camera?
Camera: Canon PowerShot A40
If you're photographing stationary objects and have your camera on a tripod, in a sense the amount of light available doesn't matter, because it doesn't matter how long it takes the camera to take the exposure.
For comfortable hand-holding I've previously used 5 x 100 W flourescent bulbs which was definitely enough. (but that was through a homemade softbox, not into a light tent)
You're only using a single light? Where are you positioning it?
You're going to want at least three lights, not so much for the "quantity" of illumination, but rather for the quality or eveness of it. The normal use for a light tent is to provide soft, even lighting for small product photography, and one light just isn't going to cut it.
I am using 3 of the Philips 23-Watt(100-Watt) Energy Saver Compact Fluorescent Warm White (3500K) Light Bulb (E*) 60 watt desk lamp with a flexible neck. There will be one lamp on each side where there is a cut out covered with white muslin fabric and one on the top with another opening. The box is almost finished and has all the sides. I placed the lamps on the sides and I could see that the box is filled with a soft even light with no shadows. For a novice it look pretty good.
I am using a Canon PowerShot A40 and wondering if I should use Automatic or Manual and set the speed differently. I really don't know anything about it and will have to find an article on the internet that talks me through it. I will just take several pictures from each and see which is the best.
I am using a tripod.
Auto will do the job since you are using constant lights. I bet you'll need a tripod though because the shutter speeds are going to be down to 1/30. Unless you are a VERY steady holder you are doing to introduce motion blur from the slight movements you will make in that time.
i am a very unsteady holder and try not to hand hold under 1/100 or 1/80 for sure.
