Which one is better?
kharp
Arkansas
I have these similar shots. I was hoping to get some opinions on which is the best of the three... Thanks in advance. :)
I prefer no 1.... But there is soo much grass in front of cars that doesn't really do anything for me personally. I'd have put cars/horizon lower down in the frame. (Google rule of thirds)
Just my opinion and I'm no expert :-)
You should have been more creative with the subjects.
You could try a 'creative crop'. Make it 16:9 or slimmer for a letterbox or even cinematic look. Doing that should take some attention away from the grass and trees, you might call it 'negative space'.
Number two would be my favourite of the three.
Ta da! Just a thought.
Yeah I think you've got too much grass and not enough of the cars. Try to make it a little more dynamic. Perhaps stand close to the back end of one and try and get the other two in your shot as well. Get your depth of field going a little. How can I put this? Don't go for the typical photo. Try to get as many different and interesting angles as possible because they usually come out better more often then not. It causes interest in the viewer.
I like three the best though. The way the cars are facing make it look pretty cool.
Thanks for the comments. :) I've shot a lot of cars, but not three at once. I have this one too. I wasn't going to show it cause I still don't really like it all that much. I don't usually like camera tilt but I tried it for this one to get the cars to fill the frame a little more. I also cropped it a little and got rid of the water tower. What do you all think?
I added the wrong photo the first time and I thought I deleted it but it's showing as an attached thumbnail...
I feel like you need to be more creative with the positioning of the cars. The one I like the most is 2 probably because the others have too much space in between cars for this pose. Maybe if you only shot parts of the cars you wouldn't get such wide shots?
they look like they are falling off of the side of the world...
Use a bit larger aperture to make the background less distracting.
