Ballistics
- Joined
- Jun 5, 2011
- Messages
- 3,781
- Reaction score
- 633
Look better than when you upload them onto a computer? I'm puzzled.
Umm... Because your monitor is a hell of a lot bigger than the little screen on the back of your camera?
They don't always look better though. Sometimes they look worse.![]()
^^ That, and the fact that your monitor may not (Probably isn't) calibrated and may be showing incorrect colours, brightness, etc.
Calibration makes a big difference?
Is this a serious question? I'm not being a smart ass... I've seen you around here, but I don't know enough about you yet to determine whether or not you're being serious...![]()
It depends on how bad your monitor is from the factory.^^ That, and the fact that your monitor may not (Probably isn't) calibrated and may be showing incorrect colours, brightness, etc.
Are you shooting RAW?
The in camera previews have processing applied to them. On the computer, that is not there unless you did it (if you're shooting RAW).
It sounds like the camera is applying presets that whatever software you are using on the computer is not applying.
I've had some monitors that were pretty close, but I've had others that were WAY off...
Unless you have a calibrated monitor to compare it to, you would never know.
edit
I don't think you would see a difference in sharpness though... But you DO want the colors to be right...
Rhetorical question really. Obviously calibrating will effect an monitors sharpness, color, etc. But to the point where it is drastic enough to alter the opinion of an image?
Sounds like a color space issue.It depends on how bad your monitor is from the factory.Calibration makes a big difference?
edit
Here is something odd, when I open the image in PS CS4... the image looks identical to the camera. If I open it in folder view, or use windows viewer, it looks like over exposed film from the 70s.
edit
What color space is your camera set to?
