Garbz
- Joined
- Oct 26, 2003
- Messages
- 9,713
- Reaction score
- 204
- Location
- Brisbane, Australia
- Can others edit my Photos
- Photos NOT OK to edit
Not familiar with Nikon.. why did they stop doing that?
There are several downsides to having an electronic shutter. One was mentioned above and that is that readout occurs across the sensor called a rolling shutter. In extreme cases this could make the results of the picture look like the slow focal plane shutters of the 60s distorting moving images. This one can be worked around through the use of a global shutter, but the last CMOS sensor I saw implementing a global shutter without sacrificing performance cost just upwards for $10k. CCDs on the other hand could very easily be read out globally as the name implies, "Charge Coupled" meaning the image is not read out from the same part which records the light. Their issue though is when the the charge is transferred and light still falls on the sensor you end up with horrendous smear or blooming.
So in either technologies a mechanical device we have more than 60 years experience with does the trick.
I was just thinking why DSLRs use mechanical shutter and are limited to shutter sync speed for flash photography. Can't they just turn the sensor on and off to whatever shutter speed you want? I apologize if this is a stupid question.
Isn't that just what P&S cameras do? I thought the main problem with an electronic "sensor on/off" system was shutter lag.
Lag is introduced on CMOS cameras. Many P&S have CCDs. The lag was just the result of outright ****ty performance. For the most part many P&S have very little actual shutter lag but were horrendously slow at powering on, focusing, readout, displaying the image, not to mention that they needed to first close the shutter and turn off liveview. Also ever notice that many P&S cameras suffered bloom in liveview but not in the final image? You'd be amazed how many of them actually had rudimentary mechanical shutters if for nothing else than to read out the data from the sensor. See D70, D40, Canon 1D for examples of cameras which used electronic shutters but negligible lag. But see above for a reason why it's bad.
Nikon d70 is old but will give you unlimited sync speed due to it's electronic shutter
Not quite unlimited. They limit it to 1/500th or 1/1000th from what I remember due to efficiency reasons. In theory the sensor can read out at a shutter speed faster than the time a flash bulb is on when fired at full power, so if you go above 1/1000th you start getting bizarre power characteristics from your flash.
