1st model shoot
Discussion in 'Critique Forum Archives' started by dezmaas, Apr 28, 2004.
  1. dezmaas
    dezmaas TPF Noob!
    Apr 28, 2004
    90
    HI...Here is a shot I took on my first shoot with a model. I added the sunlight effect with Paintshop Pro..all comments welcome.
    [​IMG]
  2. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    I think the added effects are distracting attention away from the model. I'd like to see it without the effects.
  3. Darfion
    Darfion Soapbox guru...
    Jun 13, 2003
    1,498
    14
    Wigan, Lancashire
    Sunburst or lens flare are very commonly used in either photoshop or paint shop. That said, The effect you have created is good but a bit over-used. Also in my opinion, it may be a touch on the bright side. Have you got the original photo without the effect?
    But, like i said. You have created a good picture.
  4. dezmaas
    dezmaas TPF Noob!
    Apr 28, 2004
    90
    Yeah, I still have the original photo without the effects.
  5. fotoadam
    fotoadam TPF Noob!
    Aug 12, 2003
    80
    houston and huntsville texas
    ditto, you cant see her face. she almost looks similar to Anna Kournikova..
    adam
  6. dezmaas
    dezmaas TPF Noob!
    Apr 28, 2004
    90
    Here is the original:
    [​IMG]
  7. Moni
    Moni TPF Noob!
    Feb 20, 2004
    361
    Chittagong
    Yeah! She looks like Anna :)
    I think I've to meet her soon ;)
    Dez your idea about the lens flare is good...but to keep the photo out of impurity you can avoid them for now :)
  8. markc
    markc TPF Noob!
    Mar 8, 2004
    4,237
    6
    Rochester, NY Velocity: Unknown
    I like it better without the flare. It's low on contrast, though. I would set the black point (using levels) so that her dress has some actual black in it. This might look interesting as a high-contrast image, since there isn't much light on the front of her. If that doesn't work for you, you could try a reflector to bounce the light coming in the window back on to her face.
    Backlighting is fun, but tricky.
  9. dezmaas
    dezmaas TPF Noob!
    Apr 28, 2004
    90
    Experimenting is what photography is all about!
  10. Galaxy_Stranger
    Galaxy_Stranger TPF Noob!
    Apr 21, 2004
    99
    Houston
    I agree that there's too much flare. But I get the idea. The sun showing through behind the blinds would be interesting. This is probably too much contrast, but, screw it.
    [​IMG]
    This stock lighting from Paint Shop kinda frames it, although I probably wouldn't use it:
    [​IMG]
  11. Moni
    Moni TPF Noob!
    Feb 20, 2004
    361
    Chittagong
    WoW! How you did that ???!!!???
  12. Galaxy_Stranger
    Apr 21, 2004
    99
    Houston
    Which one? The top one was just adjusted brightness and contrast. I also put in the same lens flare that he did in the upper left corner, just turned down the settings a bit - that lit up her face some.
    The second one is the same shot, but those lights in the corners are a prefabricated effect in Paint Shop. I didn't really have to do anything. I thought it looked different, so I stuck it on there.
