5D mkii underexposing?
Discussion in 'Photography Equipment & Products' started by guitarkid, May 11, 2009.
  1. guitarkid
    guitarkid TPF Noob!
    Jun 26, 2006
    231
    chicago
    i'm not sure what it is but most of the shots i take with mkii are underexposed. i always shoot M and never had an issue with any of my previous canon bodies. i've had the 20d, 30d, 40d, 50d, 5d. if i set for iso, say iso1600 for indoors, and F5.6, and shutter, doesn't matter.....the meter is always in the middle, set for proper exposure...it comes out dark!
    i then set to full auto to see what the cam would select. it chooses iso 800....half as much for indoors! the F is the same, and shutter a little different, and the shot looks great. i don't get it.
    with any of my other bodies i have always started with iso, 100 usually outside, and 800 to 1000 indoors, then Fstop based on DOF and shutter accordingly. this is how i have done it for years. this mkii is just not cooperating.
    bottom line..... regardless of settings, the meter is showing correct exposure but it's underexposed. maybe i need to jack the exp. comp setting or something, but i never had to do that before.
  2. tsaraleksi
    tsaraleksi TPF Noob!
    Jun 12, 2007
    1,045
    Greencastle Indiana
    Just figure out how the meter is reading then keep that in mind when setting your exposure. You needn't be a slave to the center of the dial.
    What meter mode do you have it in, by the by?
  3. guitarkid
    guitarkid TPF Noob!
    Jun 26, 2006
    231
    chicago
    using defaults...right from the factory.
  4. Do'Urden's Eyes
    Do'Urden's Eyes TPF Noob!
    Apr 16, 2008
    881
    Mississauga, ON
    That is bizarre. Contact canon about it see if they can suggest anything.
  5. soylentgreen
    soylentgreen TPF Noob!
    Feb 27, 2007
    735
    Miami, FL
    I have an over-exposeure problem. Sorta. My shots metered in the center are usually blown out in evaluative mode. Spot metering is an improvement, but I lose detail in the shadows. I pretty much shoot -1 EV and lighten in post. My 40D is spot on compared to the 5D mark II. Dunno if it's the FF and resolution. I should pick Canon's brain about this.
  6. rufus5150
    rufus5150 TPF Noob!
    Mar 8, 2008
    1,658
    Austin, Texas
    I don't have a 5d, but my XTi consistently under exposes even really easy to meter scenes 1/3rd-2/3rds of a stop low. Not that this helps you in the slightest but when I contacted canon, they said that that was normal.
5d mark iii underexposure problem
5d mark iii underexposure issue
5d mark ii underexpose
5d mark ii underexposing
430ex ii 5dm2 always showing underexposed
auto exposure in 5d mark ii underexposing
canon 5d mark ii got underexposed
canon 5d mark ii underexposure
canon 5d mii underexposing
canon 5d mkii under expose
