another really stoooopid question
Discussion in 'Beyond the Basics' started by captain-spanky, Nov 24, 2004.
  1. captain-spanky
    captain-spanky TPF Noob!
    Jul 14, 2003
    751
    in a bubble in Yorkshire, UK
    when you want to take a really long exposure and you set the camera to 'bulb'...... how do you know how long to hold the shutter open for? Just through experience?
    Also does anyone know if i can get some sort of device for holding the button down on either a EOS 1000fn or a EOS 50e without shaking the whole thing?
  2. Hertz van Rental
    Hertz van Rental We're supposed to post photos?
    Nov 8, 2004
    16,738
    46
    Where am I now?
    You use a light meter - Gossen, Minolta, Sekonic etc.
  3. BernieSC
    BernieSC TPF Noob!
    Jul 3, 2004
    270
    South Carolina
    usually when you are shooting bulb setting you have to bracket. It depends on how much exposure curve you want, contrast , movement or none movement. Trail and error in other words.
    Also in case you didn't know when you use bulb setting on the electronic cameras AF and AE being a new camera or now you can say older models the "B" flashes for each second you have the shutter open or however long you hold the shutter release down.
  4. photogoddess
    photogoddess TPF Noob!
    Feb 29, 2004
    6,253
    34
    Lala Land
    I tend to meter and do a ton bracketing for long exposures
    See if Canon offered a cable release for your camera. The older cameras used a universal one but no more. Now you need to buy the one specially made for your camera if that option was available with it.
  5. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    For film exposures longer than 1 sec you should consult the film manufacturer for how you'll need to adjust from the recommended meter reading to deal with reciprocity failure.
    I'd look online, but sometimes that info comes with the film. It'll be different for different films. For instance, with exposures longer than a few seconds, Tmax 100 is actually faster than Tmax 400. Even with that information, you'll probably want to bracket your shots and take notes.
  6. Hertz van Rental
    Nov 8, 2004
    16,738
    46
    Where am I now?
    For information regarding reciprocity adjustments.
    If you use Kodak films follow the relevant links to the technical information for the film you use. Reciprocity adjustment advice is there:
    http://wwwuk.kodak.com/global/en/professional/products/prodSupportIndex.jhtml
    For Ilford its here (.pdf files). Again follow the links to your film:
    http://www.ilford.com/html/us_english/homeng.html
    Agfa is here (but I couldn't find any technical info):
    http://www.agfaphoto.com/en/
    Fuji is here (again in .pdf format):
    http://www.fujifilm.com/JSP/fuji/epartners/proPhotoHomePage.jsp
    Hope this helps
  7. j_mcquillen
    j_mcquillen TPF Noob!
    Oct 3, 2004
    290
    Northumberland, UK
    Don't know anything about these cameras, but if they don't have a socket for a cable release, or remote shutter release, then you could use the camera's built in self-timer (the sort you'd use for including yourself in a family potrait) - this allows any vibrations from you pressing the button to die down, before the shutter opens.
    If the cameras don't have a self-timer either, you can buy a kind of clamp device that attaches to the camera, and allows you to fit a cable-release over the button - these work better than pressing the shutter release button by hand, as most of the vibrations are taken up by the cable, but not as well as a properly fitted cable-release.
    Jessops sell the clamps for £22.99 - click here to see the page.
  8. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    I've never tried it on my camera, but if you used the self timer with bulb setting...how would you close the shutter...without touching the camera and defeating the point of using the timer in the first place?
    I use the timer all the time for my tripod shots but I have never used bulb mode with this method.
  9. j_mcquillen
    Oct 3, 2004
    290
    Northumberland, UK
    Hmmmm...
    Thats a good point... hadn't thought of that.
  10. Jeff Canes
    Jeff Canes No longer a newbie, moving up!
    May 19, 2003
    6,192
    22
    Hollywood, FLA USA
    If you still have the manual, check in the back pages there should be list accessories
    Think I recall reading that these models may use an inferred remote
  11. fadingaway1986
    fadingaway1986 I Burn Easily :(
    Feb 4, 2004
    1,449
    9
    Queensland, Australia
    I saw somewhere, someone suggesting to put a piece of black cardboard in front of the lens when you want to close it. (after using the selftimer method.) Put the card board in front & keep it there while you press the shutter button again) That will therefore stop any light getting through when you have the movement.
  12. Karalee
    Karalee hOtLiPs!
    Feb 22, 2004
    3,849
    47
    Here....there....everywhere
    As far as I know, on some cameras you have to depress the shutter to open, and then press it again to close it, and on other cameras (like mine) you have to keep it pressed for the whole exposure. Either way I would go with a shutter release cable, cos Ive knocked mine while holding the shutter button a few times.
