Cropping Photos for Printing
Discussion in 'Photography Beginners' Forum' started by Noob7_0, Jul 29, 2008.
  1. Noob7_0
    Noob7_0 TPF Noob!
    Dec 23, 2007
    16
    Ontario, Canada
    Im knew to the whole "post production" thing. I want to get some my of my shots printed to 4x6s, which is fairly straight forward, but I was hoping to crop a number of them (if it matters I was going to have them developed at Walmart). Im not entirely sure how to crop them yet still maintain the ratio for a 4x6s print. I have CS2 and Lightroom (with no formal training what so ever in either program). Would anyone be able to give me some tips or point me to a website?
    And a slightly related question....what would happen if you had a pic that was cropped to be really wide and narrow. If you had it printed would you get a letter box effect or would the pic be streched to match the print size.
    Thanks
  2. dklod
    dklod TPF Noob!
    Sep 24, 2007
    344
    In a tent outside the gates of hell
    I use a couple of different programs each for a different purpose. For cropping, I use FastStone. It has programable cropping and preset cropping as well so you can pick your 3:2, select your first corner and when you drag your window remains at the same ratio. Other programs probably work the same, but this is the best I know of for this purpose.
  3. bigalbest
    bigalbest TPF Noob!
    Jun 5, 2008
    505
    Litchfield Park, AZ
    The crop tool in CS2 has a drop down menu (along the top of the screen) with specific sizes including 4x6. Next to that are a couple windows where you can type in any other size you want. Usually if you send a panorama style crop to wallgreens and say ask for it to be printed 4x6 they will format it to fit leaving blank space above and below the photo. :wink:
  4. maytay20
    maytay20 TPF Noob!
    Apr 30, 2008
    316
    Burton, MI
    I crop with the printers tools. If you crop then send to a printer you might get them cropped again and have chopped off heads etc. (Walmart is bad at doing this)
  5. clarbin
    clarbin TPF Noob!
    Jul 19, 2008
    57
    Litchfield Park, Az.
    Costco does the same thing.
    "Off with their heads!" At least the tops of them anyway.
  6. reg
    reg TPF Noob!
    May 28, 2008
    1,487
    Stuck inside of Mobile with the GTFO Blues Again
    Walmart is bad at doing everything.
  7. Sandspur
    Sandspur TPF Noob!
    Jan 30, 2008
    241
    Pensacola, FL
    You have CS2 - use it. Use the crop tool, choose the preset size you want, and crop it.
    Just be sure you're also specifying the resolution. (should be 300 dpi in most cases)
    I have a tutorial page about adjusting for print size here: It explains a lot about the nuts and bolts of cropping to fit.
    http://www.jimsdigitaldiary.com/8x10.html
    People who complain that this or that store chops of heads or otherwise crops their pictures badly usually haven't given the printer properly setup file.
    You can't blame the store when you didn't do the job correctly in the first place.
