From Cold to Hot?
Discussion in 'Photography Beginners' Forum' started by AnthonyCorbo, Dec 13, 2008.
  1. AnthonyCorbo
    AnthonyCorbo TPF Noob!
    Nov 26, 2008
    60
    I've been reading many threads on the issue of using your DSLR in the cold and then bringing it inside your home. What do you guys or girls think? Is it ok to bring your DSLR in the cold weather, will the screen and lenses be fine and is it ok to expose it to a warm temperature after i've read it cause foggy lenses.
    So it it ok to shoot outside and then go inside a warm home, if not what can you do to tranfer the camera safely?
    Thanks in advance:thumbup:
  2. osirus
    osirus TPF Noob!
    Jun 13, 2007
    310
    i read to stick your camera in a plastic bag before you come in, and leave it for a few hours to slowy warm to room temp
    so i bring a bag out with me now and do that when i come in, and so far its all been fine.
    lenses i will just leave in the camera bag closed for a few hours, as it stays quite cold insie my bag when i bring in inside if i leave it.
  3. mrodgers
    mrodgers No longer a newbie, moving up!
    Dec 13, 2007
    1,662
    7
    It doesn't matter how fast it warms up or how cold it is when you first bring it in or how warm it is where you are bringing it into.
    You put it in a sealed (ziplock) bag too keep the humidity in the warm environment from condensing.
    Inside the home or other heated living space is moisture, a lot more moisture than the outside air in the winter. The same thing when you wear glasses and go inside to have them fog up from condensation of the moist air will happen to your camera. If you put your camera inside a sealed bag while you are outside, you are also filling that bag with the same cold dry air as outside.
    By bringing it into the house this way, you keep the moist air away from the cold camera until the camera is warm enough that the moisture will no longer condense. It's not the temperature extremes that is the problem, it is the difference of moisture in the air.
bringing dslr from cold to hot
bringing dslr in from cold
camera moist after bringing out from a cold room
cameras hot to cold
dslr cold warm
moving dslr from cold to hot
moving dslr from hot to cold
moving dslr lens from cold to hot
using camera gear in cold then bringing inside to warm
