High Concentration of Developer
Discussion in 'Film Discussion and Q & A' started by Commonman, Dec 23, 2007.
  1. Commonman
    Commonman TPF Noob!
    Jan 4, 2007
    201
    St. Paul, Minnesota
    I failed to carefully read the instructions and used a 1:7 concentration of HC-110. I was developing film in a small tank and used this highly concentrated solution. The negative appears to have turned out OK. But, would they not have been very overdeveloped because of the over concentrated HC-110 solution?
  2. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    have you printed them ?
    that is going to be the real test.
  3. Commonman
    Commonman TPF Noob!
    Jan 4, 2007
    201
    St. Paul, Minnesota
    Ann: no, have not printed them. I will report back when I do.
  4. Chris of Arabia
    Chris of Arabia Herding cats since 1988... Supporting Member
    Mar 10, 2007
    7,825
    16
    The Magic Kingdom
    If they were overdeveloped, you'd expect them to have a very high density in all tonal areas. If you can see detail in the highlight areas, you may well have got away with it. It's possible you may see extended exposure times in your printing though.
  5. Commonman
    Commonman TPF Noob!
    Jan 4, 2007
    201
    St. Paul, Minnesota
    I think I may have gotten away with it. This leads me to believe that being obsessive/compulsive about exact measurements may not be necessary. Nevertheless, who wants to waste HC-110? I sure don't.
  6. Judge Sharpe
    Judge Sharpe TPF Noob!
    Feb 13, 2008
    307
    birmingham alabama usa
    You will be OK- I do not know what your usual working concentration is, but I generally work my Ilford a !:9 for shorter times.
    JS
  7. JC1220
    JC1220 TPF Noob!
    Sep 13, 2005
    439
    Maine
    Or, you had underexposed your film. The proof will be in the printing, thats what really matters.
  8. christopher walrath
    christopher walrath No longer a newbie, moving up!
    Mar 19, 2008
    1,265
    24
    In a darkroom far, far away...
    Be precise in your measurements. Be meticulous so that your results are spot on from roll to roll. Leave nothing to chance. That way you get into the practice of perfect. I measure my chems out to the mL everytime (well as close as I can get without a scale of some sort). Time, temperature, agitation, everything should be perfect. That way you fall into a rhythm and know what your procedure will produce. Then when it comes time to experiment, you'll know which way to go.
