How to stitch panoramas?
Discussion in 'Photography Equipment & Products' started by Val, Feb 1, 2008.
  1. Val
    Val TPF Noob!
    Dec 16, 2007
    161
    I tried in PS, but its a long and painful process :( Is there any miracle plug-in or other software to do it nice and easy? :D
  2. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Yep Panorama Tools, and PT Assembler, and Blender, and AutoPano SIFT, and all the other programs that PT assembler needs to run. Spend about a week figuring out how to configure it all. and Then you can make perfect panoramas in 1 click.
    Oh it's still long and painful though. Especially the blender application maxes out my 2gb of ram almost instantly when working on a 10mpx image.
  3. Val
    Val TPF Noob!
    Dec 16, 2007
    161
    ouch! :confused:
  4. Johnboy2978
    Johnboy2978 No longer a newbie, moving up!
    Oct 21, 2004
    1,797
    30
    Southwest Virginia
    I use panorama factory by Smoke City Designs:
    http://www.panoramafactory.com/
    Runs about $80, you can import all your pics adjust the setting and click ok. It does a decent job usually. I had one recently though that never came out very well with it or with PS, but I didn't use a tripod. It was kind of spur of the moment kind of thing, and I did it better by hand than either program did. Took a Loooooong time though. 99% of the time, this program works pretty well especially if you use a tripod. Takes a while for it to churn out though if you have several images.
    They do have a 30 day free trial though.
  5. astrostu
    astrostu Guest
  6. Puscas
    Puscas TPF Noob!
    Oct 7, 2006
    1,884
    Brooklyn NY
  7. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    as already mentioned... get lots of memory in your conputer! especially if you work with 16 bit images and lots of megapixels in the images to stitch.
  8. Ockie
    Ockie TPF Noob!
    Feb 8, 2007
    704
    Málaga, Spain
    If you bought a Canon dSLR you should have gotten a CD with it that has "Canon PhotoStitch" on it... should also work, and at least its free ;)
  9. Val
    Val TPF Noob!
    Dec 16, 2007
    161
    Comp is fine, i have 4gb of ram and 2,4ghz x 4... Should be fine.
    So far i tried PanaVue Image Assembler and a quick handheld pano, although greatly reduced in size since im on my laptop now. It worked great even though i left everyhting on auto.
    Have you guys tried it? How does it compare to other soft?
    It would be awesome if you wrote that you tried different progs and the ones you chose, instead of "i use this" :D this way everyone interested can decide which program not to use.
  10. Val
    Val TPF Noob!
    Dec 16, 2007
    161
    Just tried AutoPano Pro... Its leaps and miles better.
    PF isnt very good at all apparently...
  11. Mr_Bester
    Mr_Bester TPF Noob!
    Jun 25, 2007
    57
    St. Louis, MO
    I know I'm late, but I use Hugin as the frontend with auto-pano sift. I haven't had problems other that poor exposures on my first, and the software can't fix that;)
  12. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    try Serif, it is terrific, and the cost is not over the top , about 50 dollars.
