HX90V
Discussion in 'Photography Beginners' Forum' started by danisat, Oct 11, 2017.
  1. danisat
    danisat TPF Noob!
    Oct 11, 2017
    28
    yes
    this is with remote, stabilization off and tripod why?
  2. jcdeboever
    jcdeboever TPF Supporters Supporting Member
    Sep 5, 2015
    14,124
    7,516
    Michigan
    Curious is all. Most people do not consider using them with the point and shoot zooms. They can make a difference. I have a Canon SX60HS and it is very helpful with it. I did notice on mine when you get into that digital zoom range I get that watercolor effect in the images. I think it has more to do with the small sensor size. However, if I stayed out of that digital zoom range, the image quality was very good when stabalized or even hand held.
  3. danisat
    danisat TPF Noob!
    Oct 11, 2017
    28
    i work only with optical zoom :)
  4. danisat
    danisat TPF Noob!
    Oct 11, 2017
    28
    Hi
    Why in 30x I can not focus on long distances and in 29x or 28 x y es?
  5. benhasajeep
    benhasajeep No longer a newbie, moving up!
    May 4, 2006
    4,021
    494
    I would take a similar picture with the lens zoomed half way out on an object a similar distance. Then on computer enlarge to check focus. Also is there a filter on the end of your lens?
  6. danisat
    danisat TPF Noob!
    Oct 11, 2017
    28
    I have not understood your question?
    Filter?
  7. danisat
    danisat TPF Noob!
    Oct 11, 2017
    28
  8. danisat
    danisat TPF Noob!
    Oct 11, 2017
    28
    Benhasajeep
    Can you explain again tour proposal?
    Thanks you
  9. danisat
    danisat TPF Noob!
    Oct 11, 2017
    28
    1. Your proposal
  10. benhasajeep
    May 4, 2006
    4,021
    494
    It's just a focus test. Take your lens and set on tripod. And at several zoom settings take pictures of the same scene. I would also do it at different aperture settings as well. So maybe 16 pictures in all. 4 different zoom lengths and 4 different aperture settings. Then take the pictures to the computer and zoom in on screne to check the quality of the pictures.
    Even the best of lenses, especially zooms, will have "areas" where it's not as sharp as others. Most likely at either end of the zoom range and at largest aperture.
  11. danisat
    danisat TPF Noob!
    Oct 11, 2017
    28
    the problem that from a certain distance the lens does not focus on 720mm 30x ... so the samples will be within the distance that if focus ...
  12. benhasajeep
    May 4, 2006
    4,021
    494
    An inexpensivly made filter will also affect a lens. Was wondering if a filter was on the lens during the poor IQ shots. And if there was a filter. What quaity is it?
