Is Unsharp mask the best way?
Discussion in 'Digital Discussion & Q&A' started by Mary, Aug 17, 2007.
  1. Mary
    Mary TPF Noob!
    Apr 28, 2007
    85
    A luvly place in Ireland
    Hey Everyone,
    i was just wondering is unsharp mask the best way to give a bit more sharpness to an image, i use it and leave it as it is, 50% at radius 1, is this d right way to use it, also what is the quick way to use it for alot of images at once,
    your advice would be great, thanks :)
  2. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    There are different ways to sharpen. U.S.M. is a pretty good way to do it, but I find that different images often need different levels of sharpening.
    Sharpening could be considered an art, in it's own right. Often, the best results are created by sharpening in multiple passes or steps.
    Just make an 'Action', then you can run it with click or run it on a batch of images.
  3. zendianah
    zendianah TPF Noob!
    Mar 29, 2007
    1,310
    Denver, CO
    Mike How do you run an action on a batch of images?
  4. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    Open the Photoshop file browser and then under the 'Automate' menu is 'Batch'. Just run that command and it will let you pick a group of files (or a folder) and an action to run on them. You can set options for saving the images or saving copies to a different folder etc.
  5. domromer
    domromer TPF Noob!
    Aug 11, 2007
    878
    Eugene, Oregon
    I copied this off another page, didn't feel like all the typing before the coffee kicked in, I uses batch functions all the time they are great. Did you know once you create an action you can send it like any file and someone else can load it on their computer, or you can go to an action website and download all sorts of cool actions.
    To begin this process you need to create an action. If you don't know how to do this or never used Photoshop's actions before, I'll explain it. First you must create a new action from the actions menu, give it a name and hit the record button. Photoshop will now memorize everything you do in between pressing the record button on and off. Just like a tape player (am I old?). In my case, I would load my image, press record, then reduce the resolution and change CMYK to RGB. After I'm finished with all my actions I would hit the record button again to stop recording. Photoshop now knows that every time that action is played it will recreate everything you've done in the recording mode. Remember to give your action a name.
    Now, on to automating the actions via the batch command. From the actions menu select the batch command. It will then show the batch dialogue box. You have little variety here to select from, which is good because it makes things pretty easy. In my case, I just wanted to modify each file then load a new one and continue in a loop. So select a destination folder where all your graphic files are, then select one of the actions to be performed on each file. Select the option (Save and Close). Photoshop will now be automated. You can watch as Photoshop mechanically and quickly goes through all your files while you can sit back and relax. Your boss might be impressed as he wonders how you completed the task so efficiently, while you didn't even break a sweat.
  6. Jon, The Elder
    Jon, The Elder TPF Noob!
    Jul 10, 2007
    376
    Southeastern Michigan
    Now that is a worthwhile post !
    Thanks a lot.
  7. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    I haven't' used USM in a long time. I stick with the smart sharpen tool, it's much better.
  8. Hertz van Rental
    Hertz van Rental We're supposed to post photos?
    Nov 8, 2004
    16,738
    46
    Where am I now?
    You'll find I gave a step by step for batch processing in PS in this thread 2 years ago.
    http://www.thephotoforum.com/forum/showthread.php?t=33424
    It's always worth doing an archive search before asking a question. The answer is usually in there somewhere ;)
  9. Mary
    Mary TPF Noob!
    Apr 28, 2007
    85
    great, thanks guys, i will put ya advice into action (",)
  10. deputydan
    deputydan TPF Noob!
    Jun 5, 2007
    53
    308*402
    I very rarely use the usm when I'm sharpening my images. I use the high pass method instead, seems to work rather well.
    What you do is create a copy of the layer (ctrl+J) and set it to overlay. Then go to the high pass filter under the filters menu and use the slider to adjust the sharpness.
  11. scottdg
    scottdg TPF Noob!
    Aug 7, 2007
    78
    Does anyone know if Lightroom does as good using the sharpening sliders as Photoshop does? I have not used either technique much to notice a difference.
  12. danalec99
    danalec99 TPF Noob!
    Mar 14, 2004
    8,345
    68
    I use Kevin Kubota's 'KPD Magic Sharpen' for sharpening.
    For batch process, I use Dr. Brown's (free) Image Processor.
    You could simultaneously batch convert to .jpg, .psd and tiff to different folders.
    For batch conversion to jpeg's (from tiff or psd), I use Dr. Brown's (free) 'Jpeg 1 2 3'. With one click you can create three different sets (in 3 separate folders) of jpegs with different inputs - sRGB, RGB, resolution and/or different sizes, along with an action.
    I normally have two sets of jpegs - for print and web.
